RE: Problem with self test: heater/thermistor not connected?
Yikes. From your pict there are multiple problems.
Of course the critical filament sensor jack is obscured by the ribbon connectors in your pict, but I don't see your extruder thermistor plugged in. It is the one with yellow/green shrink wrap.
Check your filament sensor plug. It looks reversed left/right. From left to right I should see white, black, red. In your pict, white appears to be on right.
I also think your power panic is plugged into the heater thermistor jack.
Connections should be as below
Publié : 23/09/2019 8:34 am
Topic starter
answered:
thanks, it solved the issue 🙂
Publié : 26/09/2019 11:05 am
