[Gelöst] Printer skipping area of layers
Seite 2 / 2
RE: Printer skipping area of layers
Have you tried a different SD Card?
Joan
Veröffentlicht : 16/01/2023 2:00 pm
Lord Tairon
(@lord-tairon)
Of course I tried different SD cards.
Veröffentlicht : 16/01/2023 2:02 pm
wickdraws
(@wickdraws)
Hope ur doing well, I’ve had the same issue for weeks now too, any updates?
Veröffentlicht : 03/02/2023 7:10 pm
Dwight
(@dwight-2)
Im having the same issues. Have you any success in solving this?
Thanks in advance
Veröffentlicht : 01/03/2023 11:03 pm
CWCDesigns
(@cwcdesigns)
Any update to this? I just experienced this problem for the first time last night as well.
Veröffentlicht : 22/05/2023 1:18 pm
Dombi3D
(@dombi3d)
Mitglied
The same here! Looking for the solution!
Veröffentlicht : 04/11/2023 5:51 pm
enganear
(@enganear)
Hi, same problem almost two years after your post. Did you find the answer? I have changed everything except the motors and frame and it is driving me crazy. Tomorrow I will try the refresh, but with a new einsy and display board, I have my doubts. It is interesting that you had success using your PC.
Posted by: @lord-tairon
Update:  to connect the printer with usb to my computer works fine. i was able to print a lot of different moddels. The error , that the printer is stuck in a loop did not apperad here. I think its some hardware problem with the sd card reader or the eprom to store the gcode readed form the sd card.
I will try to change the Einsy board and check if this will eliminate the error.
Veröffentlicht : 17/12/2024 1:40 am
Seite 2 / 2
