RE: Printer skipping area of layers
Have you tried a different SD Card?
Joan
Of course I tried different SD cards.
Hope ur doing well, I’ve had the same issue for weeks now too, any updates?
Im having the same issues. Have you any success in solving this?
Thanks in advance
Any update to this? I just experienced this problem for the first time last night as well.
The same here! Looking for the solution!
Hi, same problem almost two years after your post. Did you find the answer? I have changed everything except the motors and frame and it is driving me crazy. Tomorrow I will try the refresh, but with a new einsy and display board, I have my doubts. It is interesting that you had success using your PC.
Update: to connect the printer with usb to my computer works fine. i was able to print a lot of different moddels. The error , that the printer is stuck in a loop did not apperad here. I think its some hardware problem with the sd card reader or the eprom to store the gcode readed form the sd card.
I will try to change the Einsy board and check if this will eliminate the error.
