"Please check the IR sensor connection"
I meticulously put the printer together and all went well (or so I thought)..
Turn the printer on after flight check and PINDA/bed adjustment.
Selected the wizard setup, and instead of the self test, i am getting a "Please check the IR sensor connection, unload filament if present" If i click the OK button, then it's asking me to insert filament (do not load it)
Why? isn't it suppose to perform the self test first? I read over the IR troubleshooting guide and check everything (wire connection, etc).. the filement sensor in the settings shows "0" and a "1" when i insert filament.. so it looks like it's working. what's the problem?
so i guess this is actually part of the self test. kind of confusing because it seems like it's literally asking to check if there is a problem with the IR.
