PETG print stuck
Floyd
(@floyd-2)
Miembro
PETG print stuck
I haven't done any print for a long time, due to health problems. I'm better now so I thought I would print a couple of things. Sadly I had forgotten the basics, so I printed with PETG on the smooth PEI sheet, and now it is stuck. I should have wiped it down with Windex of course, but I didn't. The print failed anyway, but I can't get it off. Is there any solvent that'll do the job? or should I use a heat gun? I hesitate to use any sharp tools for fear of ruining the PEI sheet
Any help would be much appreciated
Kurt
Respondido : 11/11/2023 9:20 pm
3Delight
(@3delight)
Moderador Moderator
RE: PETG print stuck
I hope someone can help you with this as from what I've read online it is a nightmare  to separate without damaging the PEI covering on the sheet.  Some suggestions I've read include:
1) Putting it in a freezer for several hours then flexing the steel sheet.
2) Heating the bed up to around 100°C and again flexing it.
3) Slowly working around the join with a very sharp blade like a scalpel.
The lesson here really is always use a release agent with PETG on PEI... Or use a satin or textured plate.  Sorry I can't be of more help!
Respondido : 11/11/2023 9:38 pm
Floyd
(@floyd-2)
Miembro
@3Delight
Thanks for trying to help. The freezer trick sadly didn't help. Trying other ways I managed to ruin the coating, so it's for the bin. Fortunately, I've got a textured build plate too.
Cheers
Kurt
Respondido : 13/11/2023 9:45 am
try dribbling Isopropyl Alcohol, on the build plate, around the model, let it sit a while, then re try removing the model.
Respondido : 13/11/2023 10:17 am
Dante
(@dante-3)
Might be a little late to the party, but I have found that heating the build plate to 90 - 100 C softens it up and will usually allow the part to release.  I had this issue early on and do not like to print PETG on PEI after that.  I always use the textured plate now.
Respondido : 13/11/2023 7:42 pm
Floyd
(@floyd-2)
Miembro
@Joan
Sorry, that didn't quit do it either
@Dante
3Delight mentioned that above, didn't work. Maybe I should leave it to stew for a little longer.
Anyway, as I said earlier, I managed to ruin the PEI plate along the way, but I tested your suggestions nonetheless hoping it might be of use to somebody else.
Thank you for your efforts.
Cheers
Kurt
Respondido : 13/11/2023 9:26 pm
