Nozzle too high
uwe.spahr
(@uwe-spahr)
Nozzle too high
hello after i had installed my mk3 s i let the test print go through. the filament was not pressed onto the bed but from a distance of about 1mm the nozzle was just dropped and pulled behind
I set the pinda probe to cable tie thickness as in the instructions while at the same time contacting the nozzle with the bed without a magnetic plate.
since the live z nozzle can only be adjusted in the minus range, I don't know how to adjust the nozzle closer to the heating bed.
maybe the pinda probe has an error ??
Respondido : 19/02/2020 8:22 pm
rmm200
(@rmm200)
RE: Nozzle too high
The more negative Z is, the closer the nozzle is to the plate.
Most people - and most plates - seem to wind up in the range of -.500 to -1.000.
If you are playing around with adjustments, put a piece of paper on your print plate. You don't want to scratch it.
Respondido : 19/02/2020 8:49 pm
RE: Nozzle too high
Posted by: @uwe-spahr
On the LCD screen there is a menu item "live z-adjust" where you can adjust the height until the distance to the PEI sheet fits.
This point is discussed a lot in the forum:
Respondido : 19/02/2020 9:44 pm
