[Risolto] No filament pulling, maybe missing a screw ?
cyr.paulhiac
(@cyr-paulhiac)
Hello,
I met an issue with my prusa MK3S: It doesn't load filament at all.
When I manually force the filament down to fill into the extruder, some melted PLA actually exits through the nozzle. Therefore, I don't think the heat sink is clogged.
But !
If I open the extruder part, I see that putting aside the two gears part (which grip the filament), when I call the command "Load Filament" the motor axis rotates, but not the gear itself...
After looking more into the issue, I noticed on the manual pictures that the gear cylinder has a screw to solidarize it with the motor axis:
(just bellow the right red arrow)
Again I see it in this official video tutorial:
But in my case (the machine was delivered as-is, already assembled), I don't see any screw there, only a bare thread pitch...
Is that what's causing my filament problem? Is the piece missing? If not, how can I fix the issue, please?
Thanks for reading this!
Best Answer by JoanTabb:
there should be an M3 grub screw, 2mm long, holding the Bondtech gear still.
have a look at the magnets, which are under your heatbed, there nay be a grub screw stuck to them,
Have a look in your spare parts pack.... there may be a spare one in there...
when you do find the grub screw, please use a flat ended allen key in preference to a ball ended allen key because ball ended allen keys tend to break grub screw sockets
Postato : 05/04/2020 3:42 pm
RE: No filament pulling, maybe missing a screw ?
Postato : 05/04/2020 5:12 pm
cyr.paulhiac
(@cyr-paulhiac)
Oh thank you !
So now I have identified my problem^^. What a relief !
Unfortunately, I have found no spare parts for that screw.
Can you or anyone link me a reference for that particular part ? (like on amazon ?)
I know it will be difficult to be delivered in these apocalyptic times, but that is the point I wanted to ressurrect my printer^^.
Cheers,
Postato : 05/04/2020 7:38 pm
I couldn't find them on amazon,
https://www.ebay.co.uk/itm/M3-3MM-HIGH-TENSILE-12-9-SOCKET-SET-SCREWS-CUP-POINT-GRUB-SCREWS-ALLEN-SOCKET/122038784966?hash=item1c6a1413c6:m:mCMiu7hGtTpcfd5zjDr3ddQ
in the type box choose
M3 x 2mm
then select your quantity!
best wishes Joan
Postato : 06/04/2020 12:05 am
Matteo Cristini
(@matteo-cristini)
Friendly reminder that this is the prusa Mini forum... Don't want to sound grumpy but lately it's been getting filled with mk3s posts.
Postato : 06/04/2020 7:28 am
cyr.paulhiac
(@cyr-paulhiac)
Oh thank you very much Joan  !!!
I have no idea to find this kind of parts on ebay oO.
I'm so sorry matteo I mislocated my topic ><. I did not know the mini existed 😲 .
I searched if I can move it but I do not find a way to do it myself but be free to move it if needed.
By the way, I think my kind of issue can happen to every model^^.
Postato : 06/04/2020 11:04 am
Relax Guy's it's been moved!
@cyr-paulhiac,  If you click on the link I sent above, you should be taken to the english ebay site, I don't know which area  you live in...
where are you located please?
Postato : 06/04/2020 1:34 pm
cyr.paulhiac
(@cyr-paulhiac)
Yes, thanks again^^.
I was able to switch to my region's ebay and find the equivalent.
Hope to see if I can manage to receive the missing piece in time and being useful to the pandemic.
Cheers
Postato : 07/04/2020 1:23 am
