No filament pulling, maybe missing a screw ?
I met an issue with my prusa MK3S: It doesn't load filament at all.
But !
If I open the extruder part, I see that putting aside the two gears part (which grip the filament), when I call the command "Load Filament" the motor axis rotates, but not the gear itself...
After looking more into the issue, I noticed on the manual pictures that the gear cylinder has a screw to solidarize it with the motor axis:
(just bellow the right red arrow)
https://help.prusa3d.com/en/article/filament-not-loading_2014&source=gmail&ust=1586186595483000&usg=AFQjCNG6rFi7RyKP6RRKN-Zk924mqi7RH Q"> https://help.prusa3d.com/en/article/filament-not-loading_2014 [Source: Step 11 Extruder assembly - idler (part 1) ]
Thanks for reading this!
Best Answer by JoanTabb:
there should be an M3 grub screw, 2mm long, holding the Bondtech gear still.
have a look at the magnets, which are under your heatbed, there nay be a grub screw stuck to them,
Have a look in your spare parts pack.... there may be a spare one in there...
when you do find the grub screw, please use a flat ended allen key in preference to a ball ended allen key because ball ended allen keys tend to break grub screw sockets
RE: No filament pulling, maybe missing a screw ?
Oh thank you !
So now I have identified my problem^^. What a relief !
Unfortunately, I have found no spare parts for that screw.
Can you or anyone link me a reference for that particular part ? (like on amazon ?)
I know it will be difficult to be delivered in these apocalyptic times, but that is the point I wanted to ressurrect my printer^^.
Cheers,
I couldn't find them on amazon,
in the type box choose
M3 x 2mm
then select your quantity!
best wishes Joan
Friendly reminder that this is the prusa Mini forum... Don't want to sound grumpy but lately it's been getting filled with mk3s posts.
Oh thank you very much Joan !!!
I have no idea to find this kind of parts on ebay oO.
I'm so sorry matteo I mislocated my topic ><. I did not know the mini existed 😲 .
I searched if I can move it but I do not find a way to do it myself but be free to move it if needed.
By the way, I think my kind of issue can happen to every model^^.
Relax Guy's it's been moved!
@cyr-paulhiac, If you click on the link I sent above, you should be taken to the english ebay site, I don't know which area you live in...
where are you located please?
Yes, thanks again^^.
I was able to switch to my region's ebay and find the equivalent.
Hope to see if I can manage to receive the missing piece in time and being useful to the pandemic.
Cheers
