New MK3 calibration issue
Henry
(@henry-6)
I made it through the initial test and started the calibration. Each time the z axis goes up about an inch goes back down to the bead and stops with an error message that calibration failed. I can run the z axis up to the top and run the z calibration and it works. if i run it from the bed it goes up about an inch and stops. I have tried everything i can think of and nothing works.
Respondido : 16/09/2018 12:56 am
thrawn86
(@thrawn86)
Re: New MK3 calibration issue
its pretty sensitive during calibration and slightest binding or misalignment will cause it to fail.
check the tension on your trap nuts for a start. I personally leave them slightly loose and then hand-tight after maxing out the z height by hand.
Respondido : 16/09/2018 2:50 am
Henry
(@henry-6)
I will check the trap nut tomorrow. Other information i have updated the firmware to the latest copy. If i run just the z calibration it works, and i can perform a mesh bed leveling and it works. I can print. I just cannot perform a xyz calibration.
Respondido : 16/09/2018 4:41 am
Henry
(@henry-6)
I just got through with a chat with customer support and the problem was the PINDA probe. The probe tested good but was giving different answers when detecting head height. New probe on the way.
Respondido : 17/09/2018 1:02 am
