Moire pattern in first layer calibration
RedHeadedPixel
(@redheadedpixel)
While calibrating the Z-height for my first layer I have some Moire pattern action going on. Not sure how to proceeed at this point. Need help from more experienced folks. TIA.
Best Answer by JoanTabb:
It would appear that you are way too high.
have you seen the Life Adjust 'Z' My Way, process by Jeff Jordan?
that covers adjusting live Z on a Prusa Printer.
this image shows how small differences in Live Z make Big differences in quality...
the actual values shown are unique to MY Printer. yours will be different.
none of my examples are as far above the build plate as your printer appears to be.
I suggest you follow the Life Adjust Z process...
Opublikowany : 13/01/2022 8:08 pm
Swiss_Cheese
(@swiss_cheese)
RE: Moire pattern in first layer calibration
lower your Live Z your to high, way to high.
The Filament Whisperer
Opublikowany : 13/01/2022 8:12 pm
RedHeadedPixel
(@redheadedpixel)
Thanks. I've lowered the z-height a lot more. Am I still too high?
Opublikowany : 13/01/2022 8:35 pm
Opublikowany : 13/01/2022 10:02 pm
Swiss_Cheese
(@swiss_cheese)
@redheadedpixel
yes, try to follow Joantabb's example. you need to go much lower. the Life adjust Z, post that Joan made should help.
Regards
Swiss_Cheese
Opublikowany : 14/01/2022 2:54 am
RedHeadedPixel
(@redheadedpixel)
I will study Jeff's article now. Really appreciate the heads-up Joan. Many thanks. Swiss_Cheese too.
This post was modified 4 years temu by RedHeadedPixel
Opublikowany : 14/01/2022 9:41 am
RedHeadedPixel
(@redheadedpixel)
FIXED IT!  Many sincere thanks to everyone. Especially Joan Tabb. My first layer now measures 0.2mm on my digital callipers.
Opublikowany : 14/01/2022 11:01 am
