Loose extruder after step 14
C0Ncun
(@c0ncun)
all the parts are there im not missing the cover or anything but when i screw the m3x40's and make it flush with the bottom the extruder seems loose i can tighten it more but then the m3x40's would be sticking out 3mm or so. any suggestions?
Opublikowany : 23/07/2020 4:35 pm
Walleye
(@walleye)
RE: Loose extruder after step 14
3mm stick out is a lot, are you sure you got the right length bolt?
Opublikowany : 24/07/2020 5:32 pm
C0Ncun
(@c0ncun)
@dalee1002000
yeah it was the right one after all the only one bigger is very noticeably bigger. i ended up loosening it so it was flush, continued with the x-axis carriage steps and then once that was secure and i the guide mentioned to make sure there were no  more gaps i went back and tightened it up. Everything seems good now
Opublikowany : 24/07/2020 5:52 pm
