Kedet the Golden Robot (Stringing Issues)
TylerG
(@tylerg)
Hi there PRUSAians,
I am having issues with stringing and oozing once I get to the top of my print. I have included photos of the print below.
I am using D3D Sigma Silk PLA 1.75mm Gold
I did a temp tower and retraction tower. I have included those below as well. Gave me a good temp of 200-degrees and there didn't seem to show any issues with retraction at any level.
I tried printing at both 220 degrees and 200 degrees and the results seem to be about the same.
Any insights would be helpful. Thank you.
Opublikowany : 28/11/2021 7:33 pm
BogdanH
(@bogdanh)
RE: Kedet the Golden Robot (Stringing Issues)
Did you dry the filament?
[Mini+] [MK3S+BEAR]
Opublikowany : 28/11/2021 7:44 pm
TylerG
(@tylerg)
I have not. I can give that a go.
Posted by: @bogdanh
Opublikowany : 28/11/2021 10:34 pm
BogdanH
(@bogdanh)
Even PLA doesn't absorb moisture that fast, a lot of stringing usually indicates wet filament. Anyway, when I notice extrusion is not as expected (at "normal" settings), I always dry filament first and do fine tuning afterwards.
[Mini+] [MK3S+BEAR]
Opublikowany : 29/11/2021 9:46 am
Robin
(@robin)
Can you post your zipped 3mf from Slicer? That would make it easier to suggest parameter changes...
I'd take a closer look at cooling, speed and speed for small perimeters.
Opublikowany : 29/11/2021 10:41 am
TylerG
(@tylerg)
So I did dry it in my oven last night and did a reprint. I found it to be marginally better, maybe. I think there might be something else going on. I will post the file here shortly.
Posted by: @bogdanh
Opublikowany : 29/11/2021 5:34 pm
TylerG
(@tylerg)
Here is the file
WR_Kedet_Awards_3D-Model_PRINT-READY
Opublikowany : 29/11/2021 5:35 pm
TylerG
(@tylerg)
Most recent print
set at 205 degrees instead of 215
Opublikowany : 29/11/2021 5:46 pm
TylerG
(@tylerg)
Posted by: @robin
BogdanH
(@bogdanh)
Before I continue... please keep in mind, that I'm only guessing according to your latest photos. It's actually impossible to give concrete settings for your filament.
Looking at the crown... Such small details close to each other (tips of the crown), will always produce some stringing. A bit more or less stringing can depend on filament and fine tuning -but there will always be some.
What "worries" me more, is the nature of stringing between crown and "antenna" in the center of the head. Here you can see small "bubbles" on strings, which can be because hotend is partially clogged. I would also guess on wet filament, but you say you dried it, and I take that as a fact. Finally, it can depend on filament quality.Have you tried to print the same object with another filament? That way you could determine if it's printer to blame, or it is filament.
[Mini+] [MK3S+BEAR]
Opublikowany : 29/11/2021 7:25 pm
TylerG
(@tylerg)
I will give the print a go with the grey filament that came from PRUSA.
Posted by: @bogdanh
Opublikowany : 29/11/2021 7:39 pm
