Initial build - Lubrication?
SS220
(@ss220)
Finished a kit build of the MK3S over the weekend. It was fun and all is working.  I didn't see anything about lubrication after the initial build, but I may have missed something. Is that necessary?
Respondido : 25/11/2019 2:29 pm
vintagepc
(@vintagepc)
Miembro
RE: Initial build - Lubrication?
Yes. The bearings ship only with shipping oil which is not a good lubricant; it's only meant to keep out rust.
PR maintains the bearings are pre-lubricated, but if you search here, you will find many posts on the correct lubricants to use and how to pack the bearings with it.
Respondido : 25/11/2019 2:46 pm
Posted by: @stevensmith
Search around for recommendations for lubricating the linear bearings. Unfortunately, it's an assembly step that is often overlooked.
Respondido : 25/11/2019 2:58 pm
Best advice is to pack the bearings with grease prior to assembly.  Lithium based (Lith-Eese, Lubriplate, etc.), or synthetic base (Superlube) are acceptable.
Respondido : 25/11/2019 11:21 pm
SS220
(@ss220)
Thanks. Is there a guide to do this after assembly? I’m wondering how much I would need to take apart.
Respondido : 26/11/2019 3:19 am
No guides, just brute force ...  You can get by with oiling the rods and working the axes back and forth once in a while.  Or try applying grease and doing the same, but the grease seals work fairly well...
Respondido : 27/11/2019 2:28 am
rmm200
(@rmm200)
Honestly, once you free the rods, removing the bearings is not bad.
Only one that takes a little digging is Y.
Respondido : 27/11/2019 6:16 am
phmalcontacts@gmail.com
(@phmalcontactsgmail-com)
