I can't dial in the calibration
Ribbits
(@ribbits)
https://imgur.com/a/ZV2sRV5
I'm out of ideas. I've run the calibration wizard several times, done a nozzle clean (including partially disassembling the extruder head), and tried a variety of live Z offsets. I don't know what the issue is and I can't solve it. Things were printing fine earlier in the month, but I was trying to solve my calibration for articulated prints and now I can't even print the benchmarks that came with the printer.
Questa discussione è stata modificata 4 years fa da Ribbits
Postato : 24/07/2022 10:20 pm
RE: I can't dial in the calibration
my post in this thread may help.
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/assembled-mk3s-kit-cant-get-past-the-calibration-without-problems-nozzle-to-high-then-nozzle-drags-paper-in-xyz-cal/
Postato : 24/07/2022 10:39 pm
Ribbits
(@ribbits)
Thanks for your input, I'll certainly try some of the stuff in there. I've been able to run the XYZ calibration without any paper snags, so I don't know if the PINDA sensor is currently the problem. I used the "sheet of paper and credit card" method to set its height after the zip tie method suggested in the build manual left the sensor too high.
Postato : 25/07/2022 3:25 am
