How does your Y-axis feels ?
Olivier
(@olivier-5)
Hi there,
Just got my new printer finished. I could calibrate and print the PRUSA logo with a decent result
Now I it looks the Y-axis has an issue since it tries to over-run the maximum point and makes a strong noise (motor is blocked because reaching the carriage endpoint). If I try to move the Y manually (thru the menu) I can only go from +6 to -4 and I'm not able to move the plate to the extreme other end via the menu.
I re-ran a XYZ calibration but the same happens during that process.
Powered off, I try to move in the Y-axis with the hand and I feel that the motot isn't moving smoothly. I mean it's easy than after 5cm the torque is getting (a bit) harder then smooth then harder....and so. Other axis are always smooth along the whole cariage excursion.
Is it also the same to you guys ? Or do I have an issue there ?
Thank you
Olivier
Best Answer by jsw:
It should always slide smoothly in the Y direction.
A good sanity check is to temporarily release the belt.  The bed should then slide smoothly from one end to the other with very little friction.
This will tell you if the friction is due to the bearings and rods, or the motor, pulley, and belt.
Respondido : 10/10/2022 3:18 pm
jsw
 jsw
(@jsw)
RE: How does your Y-axis feels ?
Respondido : 10/10/2022 4:13 pm
Miembro
Low friction is what I feel.  The key to testing it is a firm but consistent pressure in the X orY direction if you are testing belt tightness.
Respondido : 10/10/2022 4:15 pm
1 les gusta
T. Beck
(@t-beck)
Try lubing the bed bearings. Sometimes they run dry and cause a twisting moment in the Y-axis thus increasing friction. I’ve has this same problem and lubing the bearings fixed it.
They should run freely on the rods.
Respondido : 10/10/2022 4:20 pm
1 les gusta
vaflis
(@vaflis)
With powered off  printer carriage not moving smoothly: You can try to loosen grub(locking) screws on your y axis motor pulley and rotate pulley on shaft by, lets say, 90 degrees to one side or the other (tighten grub screws) and when check operation, if it gets better or worse. Try to find best position with uniform resistance to movement.
Respondido : 10/10/2022 6:11 pm
1 les gusta
Olivier
(@olivier-5)
Thank you to all of you. It's good to know it go with low friction and be constant. There's definetly something in there then....
I'll check that and let you know.
Have a great day.
Respondido : 11/10/2022 8:24 am
Olivier
(@olivier-5)
Looks the Y-axis pulley was slightly touching the motor. Y-axis moves somoothly from end-to-end now. Thankx for your help.
Respondido : 11/10/2022 11:19 am
