Grease Recommendation
Hello,
Newbie here. I could not find the recommended grease brands here in Turkey with a reasonable price.
I can find SKF LGMT 3. Lithium Grease for bearings.
What do you think about it?
Thanks.
Best Answer by Clarmrrsn:
Check this thread
There are also recommendations in the regular maintenance doc
https://help.prusa3d.com/en/article/i3-printers-regular-maintenance_2072
This topic was modified 5 years temu by Bilgic
-evren
Opublikowany : 19/03/2021 11:59 am
RE: Grease Recommendation
Check this thread
Tank you very much!
Opublikowany : 20/03/2021 12:31 am
Lithium grease will be fine if you can't find anything else, just make sure the bearings are packed correctly, that is more important.
Tank you very much!
Opublikowany : 20/03/2021 12:43 am
1 ludzie polubili
