First layer problems - new printer (assembled from kit.)
Jay Newman
(@jay-newman)
Hello, all. My daughter and I spent about a year using an entry level resin printer, and just bought a i3 MKS3+ kit. Loved the instructions, all seemed to go well.
However, we do not seem to be getting satisfactory results trying to complete the first layer calibration. I have attached a photo to show the latest result.
From the instructions, it seems that being that bumpy indicates it is still set too high. However, when I go lower, the straight lines appear to be squeezed too much and variable from a clean flat line to almost translucent, leading us to believe it is set too low.
It adjusted the sensor downward and re-calibrated, reading that the results could be inconsistent if it was too high.
We have tried some test prints, and there definitely is some issue with first layer adhesion in some spots.
Any suggestions on how to correct this would be greatly appreciated!
Best Answer by JoanTabb:
try using
Life Adjust Z, My Way           by Jeff Jordan...
It's old, but works easier than the prusa first layer calibration
there are test files in a zip file at the bottom of the first post in that thread
Opublikowany : 29/01/2023 4:34 pm
RE: First layer problems - new printer (assembled from kit.)
try using
Opublikowany : 29/01/2023 5:47 pm
1 ludzie polubili
RandyM9
(@randym9)
+1 - What @joantabb said.
The built in Z level calibration is fine to get you in the general range. The Jeff Jordan ‘Life Adjust Z - my way’ will help you fine tune your Z height.
Also insure your build plate is squeaky clean or you’ll suffer adhesion issues.
And, FWIW, the ‘flag’ at the end of the calibration pic you posted looks like the Z is too low, to my eye. Good luck, you’ll get it sorted.
Cheers
Opublikowany : 29/01/2023 8:57 pm
1 ludzie polubili
Robin
(@robin)
What Randy and Joan said. A lot of people find the "my way" easier and it has the advantage to also work with different nozzle sizes....
The position of the PINDA probe is limited by the nozzle hitting the bed (PINDA too high) and PINDA hitting the printed object (PINDA too low). Between this two limits it is of no consequence where you have placed your PINDA because it always triggers at the same distance to the bed, only the distance between nozzle and bed changes with changing PINDA mounting hight. So it can not influence the consistency of your first layer calibration.
Opublikowany : 30/01/2023 11:35 am
1 ludzie polubili
Jay Newman
(@jay-newman)
Thanks, folks! Worked like a charm.
Opublikowany : 31/01/2023 1:42 pm
