First layer problem
Miiamin
(@miiamin)
First layer problem
First of all,i would like to say that the first layer calibration seem to be more then fine, but i can really not explain this fenomen(see the pictures)
It is clear that some small areas of the first printed surface it don't stick to  the bed. Can anyoane explain me why? I also cleaned the surface as Prusa has recommanded. added by Joan...  Link to: Media File, selected in add media dialogue box
Este debate ha sido modificado el hace 7 years por Miiamin
Respondido : 11/09/2019 1:29 pm
RE: First layer problem
your live Z value is too large a negative number
have a look at the first post, in the following thread
there is a zip file at the bottom of the first post that contains sample test square Gcode for PLA, PETG  &  ABS
and descriptions of how to adjust live Z n many of the posts
please note, if you select Link to Media file, when you add pictures
the pictures will enlarge when you click on them, making viewing easier
Respondido : 11/09/2019 4:04 pm
Also - only cleaning with alcohol is often not enough.  Soap and hot water are needed to rinse away oils and other contaminants.
Respondido : 11/09/2019 4:37 pm
