First layer calibration not going well. How do i fix how warped my print surface is?
creakesiv
(@creakesiv)
As you can see my bed appears to be extremely uneven. Layers towards the outside are barely sticking, and layers in the center are squished so far they almost arent there. I have tried mesh bed leveling and bed level correction with no luck. Placing paper under the edges helped, but it took almost 5 sheets to fix it, and I would prefer an actual fix. Starting to get desperate.
Best Answer by creakesiv:
Update, I turned on 7x7 Bed Leveling and it works great now. https://help.prusa3d.com/en/article/mesh-bed-leveling_112163
Ce sujet a été modifié il y a 6 years par creakesiv
Publié : 17/03/2020 5:27 pm
creakesiv
(@creakesiv)
RE: First layer calibration not going well. How do i fix how warped my print surface is?
This are my results from Pronterface running G80 and G81
-0.19667 -0.07833 0.02750 0.12083 0.20167 0.27000 0.32583
-0.14500 -0.09294 -0.03245 0.03648 0.11385 0.19965 0.29389
-0.09250 -0.08390 -0.05516 -0.00630 0.06271 0.15184 0.26111
-0.03917 -0.05120 -0.04065 -0.00750 0.04824 0.12657 0.22750
0.01500 0.00514 0.01110 0.03287 0.07045 0.12385 0.19306
0.07000 0.08514 0.10008 0.11481 0.12934 0.14366 0.15778
0.12583 0.18880 0.22630 0.23833 0.22491 0.18602 0.12167
Publié : 17/03/2020 5:46 pm
creakesiv
(@creakesiv)
Publié : 17/03/2020 6:00 pm
Steve
(@steve-5)
creakesiv,
Congratulations on getting to this point.  Now to really fine-tune your first layer I (and most of the folks much smarter than I about these printers) would strongly recommend that you follow the process outlined in this monster thread.
You only need read the first post but I think you will find that the process outlined allows much more accurate adjustment of the first layer live-Z value.  A little more time spent here will lead to a much happier place down the road due to far more reliable bed adhesion.
Regards,
Steve
Publié : 17/03/2020 11:11 pm
