Filament not recognized (any more?)
Tom
 Tom
(@tom-18)
Hi all - I've a begginners problem.
I finished assembling my MK3S+ yesterday.
Today I started with the calibration of the first layer. I'd say about 5 rounds until I was happy.
Then started to print the Prusa demo logo. But this did not work:
After checking the 9 points on the plate the printer told me to remove the filament - did so, to enter it again - did so, some of the filament was already running through it.
Then again it told me again, to remove it, to re enter it, ...
I tried it with other models - same pattern.
I tried the calibration of the first layer again (as this worked before).
But this time I cannot get it running at all - it says to enter the filament although it's already in.
Has somebody an idea what to do?
- Something I can do? Clean the nozzle (if I can do that)?
- Or better to call the Prusa support?
Thanks a lot for comments/suggestions
Tom
Best Answer by karl-herbert:
Hello and welcome to the Prusaforum!
Probably the extruder IR sensor is not adjusted correctly. You can check this by deactivating the IR sensor on the LCD and restarting a print. If this works without errors, you know what the problem is.
wbr,
Karl
Publié : 03/07/2022 7:37 pm
RE: Filament not recognized (any more?)
wbr,
Karl
Publié : 03/07/2022 9:11 pm
Tom
 Tom
(@tom-18)
Hi Karl.
Thanks for the hint.
Now the first layer calibration and Prusa logo worked.
So I can use the printer but will look what's the problem with the IR sensor.
KR,
Tom
Publié : 04/07/2022 6:40 am
Regarding IR-sensor troubleshooting -> take a look at these pages: https://help.prusa3d.com/article/ir-filament-sensor-troubleshooting-mk2-5s-mk3s_112226
wbr,
Karl
Publié : 04/07/2022 9:57 am
