Failed self test
Squidley
(@squidley)
Failed self test
I'm upgrading from a Mk3 kit that was working great for over a year. I've had the Mk3s upgrade for ages and finally decided to install it. Everything is together but I'm getting a front print fan wiring error. I'm quite sure it's correct. I've checked it several times and plugged and unplugged it several times. Could it be something else? Fuse? I broke the fan itself somehow?
Publié : 24/12/2020 8:03 pm
Squidley
(@squidley)
RE: Failed self test
Here is my wiring.einsy board
Publié : 24/12/2020 8:15 pm
Posted by: @squidley
Did you also think of installing MK3S firmware as well?
https://cdn.prusa3d.com/downloads/firmware/prusa3d_fw_3_9_2_MK3S.zip
Publié : 24/12/2020 8:28 pm
Squidley
(@squidley)
@karl-herbert
I didn't mention it, but yes, I upgraded the firmware first. It all looked like it went fine. I can try again to be safe.
Publié : 24/12/2020 8:52 pm
Squidley
(@squidley)
I've double checked my firmware. I did have 3.9.2-3524 installed and I re-installed it with no change to my error messages during calibration.
Publié : 24/12/2020 9:34 pm
@squidley
To be on the safe side, I would first perform a factory reset and then reflash the firmware.
By the way: I'm currently working with fw 3.8.1. When I flashed 3.9.2, I got the same error message. There are no hardware errors so far, so I'm back to 3.8.1.
Publié : 24/12/2020 11:56 pm
Squidley
(@squidley)
@karl-herbert
I tried flashing 3.8.1. No change.
I currently own a $1000 Prusa branded boat anchor. It's frustrating.
Publié : 26/12/2020 1:02 pm
Baklin
(@baklin)
Can you spin the fan by hand? Maybe you over tightened it and now it is stuck.
And check if you haven't pinched a cable when mounting the x-carriage-back.
Publié : 26/12/2020 10:38 pm
