Does this look right?
Niko.hogh
(@niko-hogh)
Hi I just started printed on an I3 MK3 and I think it has problems with the first layer, but I don’t know.
when I’m trying to print 0,15 and 0,20 mm layer height, the nossle rips up the prints when I get to third layer, and when I start printing the first layer it looks like this:
And the cirkle looks pretty wierd
and if I take a closer look the brim looks like this:
is this normal?
Napsal : 26/11/2020 6:44 am
RE: Does this look right?
No.  Your live Z is way too high.  You need to adjust it down (make more negative).
Follow the instruction here https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/life-adjust-z-my-way/
Napsal : 26/11/2020 6:59 am
Peter M
(@peter-m)
Clean plate with dish soap.
Then adjust your z.
Normally in the first layer there should be no gaps.
Napsal : 26/11/2020 12:32 pm
Niko.hogh
(@niko-hogh)
@neophyl
Its Wierd cause now I printed the square with the exact same settings, and it looks much better, I dont know, could it be the filament? Or could it be my slicing skills?
Napsal : 26/11/2020 6:57 pm
I think it's your live Z skills,
that square still looks to have separate lines of filament instead of a single smooth sheet with all filaments squished together!
Napsal : 26/11/2020 8:25 pm
Joan is saying you need to go a little lower.
Napsal : 26/11/2020 8:49 pm
Niko.hogh
(@niko-hogh)
Guys, now I’ve printed this, and at the start (marked with a circle) the live Z is about -1.200 and the end in the opposite end it’s around -1.270.
And throughout the print I slowly move “down” in Live Z but it has all these darker lines, and they looked like holes between the layer lines, so I kept on moving down and in the end it looks allmost see through, I don’t think that’s normal, what am I doing wrong? And yes, this is after I’ve  washed it with dish soap. So guys can you please help me?
This post was modified před 5 years by Niko.hogh
Napsal : 04/12/2020 8:10 pm
Try this process for Live Z
Regards Joan
Napsal : 04/12/2020 8:56 pm
Peter M
(@peter-m)
Setting in printer, set calibration to 7x7, is a lot better.
Napsal : 05/12/2020 11:56 am
Niko.hogh
(@niko-hogh)
@peter-m-3
I all ready use that
Napsal : 05/12/2020 1:30 pm
