Did a Micro-All-In-One-Test. Tips for improving prints?
Funkymonkey
(@funkymonkey)
So,  I have a Prusa MK3S I built myself. I printed the Micro all in one 3d printer test from thingiverse. I followed the creator's instructions to print with thin walls. My slic3r settings are set for prusament PLA, no real differences from default, other than the thin walls thing. My printer is set to PLA (it should be mentioned I am printing with the PLA that came with the printer). Now, the results aren't bad. I mean, it printed without spider-webbing everywhere, which is a win in my book. But, a friend of mine really wants me to print Minas Tirith from Lord of the Rings. That... will require good details. So, I have attached pictures of my test, and am wondering: How can I further improve my prints?
Attachment removed
Attachment removed
Opublikowany : 04/05/2019 7:00 am
toaf
 toaf
(@toaf)
RE: Did a Micro-All-In-One-Test. Tips for improving prints?
I cant see the pictures.
but I would go slower, and don't forget supports.  if you plan well it might not be too bad for cleaning them up.
I would do a .3mm print first and work out the kinks. then fine tune the resolution.  but that's me
Opublikowany : 04/05/2019 8:29 am
Use drag and drop to insert images: and then be sure you select the  [Link to Media] option before pressing [Insert].
I have a 6" casting of the scene, FDM probably can't get the details unless you use a 0.25 nozzle, or print a huge version.
Opublikowany : 04/05/2019 6:41 pm
Posted by: floofygoesflying
[...] I printed the Micro all in one 3d printer test from thingiverse. I followed the creator's instructions to print with thin walls. My slic3r settings are set for prusament PLA, no real differences from default, other than the thin walls thing. My printer is set to PLA (it should be mentioned I am printing with the PLA that came with the printer).
Just a note: Those torture test prints are handy to get an overview of how your print settings are working, but troubleshooting problems is much easier and faster with a 15-30 minute print that focuses on one problem (adhesion, stringing, bridging) rather than slogging through a 3 hour print.
Unfortunately, your pics really only show the underside of the unsupported overhangs. That test is meant to show the limits, so at 60-70 degrees, you're going to get that rough underside.
I'd suggest using some simpler prints for troubleshooting specific issues:
There are thousands of others, but the idea is to focus on one issue until you fully understand it and know how to adjust your settings.
As for the Minas Tirith print, it is likely that the model has many very fine details. Be sure to use preview mode in your slicer to verify that everything can print before sending jobs to your printer. In particular, pay attention to fine details that may be thinner than your nozzle size. You can sometimes get away with adjusting slicer settings, but very fine detail may require a smaller nozzle. Notes on nozzle sizes and preview mode here.
Opublikowany : 04/05/2019 8:41 pm
