Brim won't stick?
Dan Cooper
(@dan-cooper)
Brim won't stick?
Brim won't stick? I was able to get very nice first layer calibration but when I tried to print a calibration cube (from Thingiverse) the brim didn't stick, although the cube came out lovely.  Is this normal?  I used the grey Prusament that came with my I3 Mk3S+ kit.
Postato : 28/05/2021 9:38 pm
Dan Rogers
(@dan-rogers)
RE: Brim won't stick?
Pictures would help.  I'd have to guess your first layer was too high, or the bed is not clean, or both.  Calibration is just a first step - it doesn't mean you are dialed in.  Look up Live-Z adjustments - there are lots and lots of posts on that subject.  Calibration is just a step in getting ready to print - it will get you close to being ready to do a Live-Z adjustment.  You will have to adjust live-Z very often.  When you change filament brands.  When you change filament material type.  Sometimes even when you change color within the same brand.
Postato : 29/05/2021 8:52 am
Dan Cooper
(@dan-cooper)
@dan-rogers
Thanks Dan - I cleaned the smooth sheet with 90% alcohol and the brim is now sticking.
Postato : 29/05/2021 5:35 pm
1 persone hanno apprezzato
ssill2
(@ssill2)
@dan-cooper
generally with the smooth sheet some dawn platinum and a good scrub is all you need to get rid of fingerprints.  the 90+% IPA is really meant for the textured sheet I think.
Postato : 29/05/2021 9:49 pm
