RE: Bondtech Mk3s2 nightmare
It is important to recalibrate the Z level after replacing an extruder component, have you done that?
Opublikowany : 11/03/2020 1:55 pm
Bondtech extruder also has a different transmission of the filament feed and it is important to change the motor speed which you do with a special gcode provided by Bondtech.
For best results, use Bondtech's firmware. Don't forget to do a complete reset of Prusa's firmware first.
Opublikowany : 11/03/2020 2:06 pm
Topic starter
answered:
@rhdreambox
thank you - I realized that I hadn't reset, but didn't think it would cause that much of a clusterf*ck until you brought it up. Thanks for your help!
Opublikowany : 11/03/2020 3:26 pm
