[Résolu] Batman fails at 60%
kevinjo
(@kevinjo)
Batman fails at 60%
Wife has cleaned with soap and water and I have tried cleaning with alcohol and the batman continues to lift off the sheet around 60% completion. To me it looks good and my z axis is at -1.253. Pics of first layer is below along with final failed state. Any ideas? Thanks Final First layer Looks good to meAnother first layer First layer
Publié : 08/01/2023 8:16 pm
kevinjo
(@kevinjo)
RE: Batman fails at 60%
Pic of the spot I had to halt do to lifting. Tried to insert in original post but wouldn't go.Spot of haulting Last spot where I had to stop for lifting
Publié : 08/01/2023 8:48 pm
RandyM9
(@randym9)
See the answer below the OP in the link below. This should give you some in depth info re first layer calibration.
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/assembled-mk3s-kit-cant-get-past-the-calibration-without-problems-nozzle-to-high-then-nozzle-drags-paper-in-xyz-cal/
Cheers
Publié : 08/01/2023 9:57 pm
JandLMak3rs
(@jandlmak3rs)
Agreed first layer is not set yet. A smaller print to test is the PRUSA logo print. I did the same thing several times until I finally got first layer calibrated then it printed without peeling off.
Publié : 10/01/2023 1:24 am
kevinjo
(@kevinjo)
I lowered to 1.260 and washed again and got up to 87% completion. Went down to 1.268 and fell back to 73%. I followed the manual for the sensor but don't see where that matters as long as I can get before hitting 1.300? Looking better and better so keep going for a bit. Just wanted to make sure I wasn't missing anything as been reading about washing and just hitting that number right.  Thanks for replies.
Publié : 10/01/2023 1:34 am
RandyM9
(@randym9)
The actual number isn’t important, as long as it’s below -2.0, which is where the pinda becomes unreliable, so you can still dial down further if need be.
I think the post I linked to includes a link to Jeff Jordan’s’Life Adjuzt Z - my way,’ which is recommended for fine tuning your Z height. Hang in there… it’s a process.
Cheers
Publié : 10/01/2023 2:48 am
kevinjo
(@kevinjo)
After a bunch of side grinders, Sanders and heavy equipment 😀 ....FINALLY!!! Found a few things. The alcohol wipes were leaving a film behind and I went down to 1.388 and everything is working excellent. The items are nice and smooth. Thanks to all.
Publié : 11/01/2023 9:26 pm
RandyM9
(@randym9)
Glad to hear all is working well.
Cheers
Publié : 12/01/2023 7:09 pm
