Bad first layer Petg
PAPHOTOGRAPHY
(@paphotography)
Why do my prints with Petg look like this? Pla prints great! I been drying the filament for 24+ and it drys while printing. I have tried to adjust live Z, and reduce print speed. What more can I try?
Print temp is 240 and bed is 80.
Opublikowany : 30/12/2022 8:24 am
As a first step, I would clean the nozzle/hotend using a "coldpull". This can generally not do any harm if you change the filament type.
Coldpull:
wbr,
Karl
Opublikowany : 30/12/2022 10:41 am
Crab
 Crab
(@crab)
Have you checked your hotend for a loose screw attaching it to the rails? See if you can wiggle it back/forth. 240 might be hot for some PETG.. I often print at 220. You can try that, but seems like this is something else. Looks like this happens more when the nozzle changes direction and moving quickly, so I’d look for some looseness in belts, screws clamping the bearings to rails. Just for curiosity are you using the same sheet that you use for PLA?
Opublikowany : 30/12/2022 3:30 pm
Robin
(@robin)
RE: Bad first layer Petg
The blobs may be the result of a leaking hot end. Did you change the nozzle? Can you take a picture of your hot end (without fan shroud)?
Opublikowany : 31/12/2022 12:59 pm
Razor polubić
