ABS help
jd14
 jd14
(@jd14)
ABS help
I have some ABS I bought years ago when I knew nothing for a printer that could only do PLA...Now that there is Mk3 laying around I'm using it and the old stuff actually works well. My issue is with the new ABS-T I bought from Prusa, it doesn't work well.
1) It won't always stick to the built platform
2) It ends up not making a spaghetti mess often
3) It seems to sometimes have burns/melted areas
4) So far if ABS-T is going to mess up it usually is in the first CM or so of the print.
So... old non-transparent ABS works, new transparent ABS does not. See examples of the Vase printed in ABS. Minus the bottom on one side it was pretty good.
I tried printing dice where it worked great for a bit, except the bottom cm looked very poorly printed, then all of the sudden it started to spaghetti.
Respondido : 15/11/2018 9:46 pm
jd14
 jd14
(@jd14)
Re: ABS help
Apparently my attachments didn't make it. Let's try them again.
Respondido : 15/11/2018 10:31 pm
Texy
 Texy
(@texy)
Re: ABS help
Nope - they still didn't make it 😮
Respondido : 16/11/2018 9:21 am
toaf
 toaf
(@toaf)
Re: ABS help
maybe it need an enclosure?
Respondido : 16/11/2018 9:33 am
