Y-axis length error during belt test on a very new, previously functional MK3S+
Sameer Halai
(@sameer-halai)
Utenti
See Video
When I run the belt test, the x-axis works fine. I can hear it "bang" as it hits each side and goes back and forth. But when it does the y-axis, I notice two sounds 1) there's a soft periodic knocking sound for the whole time that the y-axis moves and 2) when it hits the back the motor continues on for 2-3 seconds even when the bed has stopped moving. Then I get the error: Selftest error! Please check: Axis length Axis Y
  1. The belt actually is tight, so I am not sure if tightening it further will help. It's inside the Prusa enclosure which makes it a little hard to get to the bottom of the y-axis unless I take it all out.
  2. I tried re-lubricating the axis but that didn't do anything
  3. When I go into Settings > Move Axis I am able to get it to go from +212 down to 0. But then it goes down further to -4 each time. It's always up to -4 each time. So it's almost like there's some -4 permanent slip somewhere.
I got this pre-assembled by Prusa in February.  I have only used it for 10 or so prints and it worked flawlessly. Then I didn't use it during the summer (3 months) during which it was sitting in a warm garage. And when I tried again I got spaghetti prints, so I tried running calibration and ran into this problem.
Any ideas what might be the issue?
Prusa Orignal 3D MK3S+
Questa discussione è stata modificata 3 years fa da Sameer Halai
Postato : 03/09/2023 9:04 pm
Hello
(@hello)
RE: Y-axis length error during belt test on a very new, previously functional MK3S+
When the bed stops hold the gear on the motor and don't let it turn to see if it stops the error the video didn't upload
Postato : 04/09/2023 3:16 am
You are using an enclosure?
Make certain that neither the bed or the cable bundle is hitting the back of the enlosure and limiting the run.
Postato : 04/09/2023 1:46 pm
Sameer Halai
(@sameer-halai)
Utenti
Thanks everyone for the suggestions. My account was locked out and I was unable to post. Here's a link to the video
Postato : 14/09/2023 1:30 am
SherryK
(@sherryk)
Utenti
Did you fix it?
Postato : 20/01/2024 1:49 pm
