No extrusion
flounder
(@flounder)
No extrusion
Printer: Prusa Mk3 S.
Extruder: E3D Revo ObXidian 0.40 with RapidChange hotend (have been using successfully for at least 10 months)
PrusaSlicer: 2.5.2
I sent something to the printer, which has been running fine.  No filament comes out.  I did some recalibrations and no joy.  The extruder is working fine; if I go to settings, move the Z-axis up, and try to advance the extruder, filament comes out just fine.  30 seconds later, printing the output from Prusa Slicer , from the SD card, no filament.
Any suggestions?
Postato : 23/04/2023 4:37 pm
MysticGringo
(@mysticgringo)
RE: No extrusion
Wrong part of the site... you want to look for the MK3s forum, this one is for the MK4. Also, I didn't think the ObXidian had been out for that long?
Try another file, if it works fine, then it's your gcode that needs work.
Is the extruder turning? Is the extruder clicking? Have you sliced for the right filament (accidentally use a PLA setting for PETG or similar)?
Postato : 23/04/2023 6:50 pm
