XYZ calibration details
From the knowledge base
"Starting with the firmware version 3.0.12, more detailed information about XYZ calibration results becomes available. This feature can be found in LCD menu -> Support -> XYZ cal. details."
Is there a way to access the same information from the system on a MK3S+ to MK3.9 upgrade?
This was a self-build MK3S+ that had an excellent XYZ calibration, which I've upgraded, so was interested to see if I'd managed to put it back together as well as when I originally built it...
Napsal : 27/11/2023 5:09 pm
