Make your i3 more silent
Sebastian
(@sebastian-8)
after the noctua fan upgrade we have another thing to make it more silent
you just need:
4 printed parts see attachment; if anyone needs an other format please just ask then I will upload if possible
8 screws fitting in the holes
4 sqash balls in double yellow dot like https://www.amazon.de/Dunlop-Squashball-Spielball-Ball-doppelgelb/dp/B00GMLA9AM/ref=sr_1_2?ie=UTF8&qid=1528316692&sr=8-2&keywords=squash+b%C3%A4lle+doppelgelb
have fun with upgrading your prusa
happy printing
Sebastian and Georg
Publié : 06/06/2018 10:29 pm
TOOCH a aimé
Alan
 Alan
(@alan)
Re: Make your i3 more silent
If anyone needs it, i've attached an STL version of the file. Just waiting on some squash balls now...
Publié : 09/06/2018 4:09 pm
TOOCH a aimé
OneThou
(@onethou)
Membre Moderator
Ha, using squash balls as dampers is very clever indeed! 😀
Publié : 09/06/2018 5:08 pm
Alan
 Alan
(@alan)
Well, i finally managed to get hold of some squash balls and tried this out. The difference is unbelievable! When I first got my MK2S, on my very first print I switched high power mode off due to the noise. Yesterday, after fitting the squash balls, I turned it back on and it's still quieter than it was in silent mode without them.
Big thanks to Sebastian and Georg for this, it really does work!
Publié : 19/06/2018 8:57 pm
digibluh
(@digibluh)
How's the print quality? it's been known that a solid rigid surface is better, despite the noise. but maybe it's fine with balls. i just updated my machine to use tmc 2208s, testing stealthchop2 to see if it will skip steps. it's silent on the motor part, but the part cooling fan is noisier now. lol.
Publié : 20/07/2018 5:20 pm
spark
(@spark)
Guess I forgot to post this. I'd like to add my hat in the ring.
Sorbothane 1" Hemisphere Adapter Set on MyMiniFactory
Isolate It 1" 4 pack on Amazon
It is far more expensive but absolutely works without need for paving stone back aches. Audiophiles swear by them, now so can I.
I have six in my set-up to spread more weight around but 4 should be fine.
MK2S kit owner since 8/15/2017
Publié : 21/07/2018 7:21 am
Vous a aimé
Sebastian
(@sebastian-8)
@eric.k4
we printed a lott of parts in the last weeks without any propblems.
since the 2.5 upgrade kit i just copy the file on the printer the rest is fire and forget.
every print is fine.
Publié : 04/08/2018 8:18 am
pbnj
 pbnj
(@pbnj)
I found that with any 3d printer a large piece of granite counter top works wonders under the printer. With out anything else. Prevents the table from acting as a speaker.
Publié : 04/08/2018 10:26 pm
spark
(@spark)
I'm of the opinion the printer should be self contained. Although Sorbothane is expensive, it keeps my printer portable while being near as silent as a 40-50 lbs (20 kg) slab of masonry that is not portable for an average geek's frames.
Publié : 05/08/2018 1:17 am
TOOCH
(@tooch)
RE: Make your i3 more silent
Here goes... going to try PLA first.
Publié : 23/04/2020 5:59 am
digbat
(@digbat)
I have gone the concrete slab and felt route - massive improvement for noise and vibration in my case.
Printer on shelves with felt block between shelves and where it touches wall (delibrate to steady the shelves). Concrete slab - felt between the concrete and shelf, threaded feet with felt inserts top and bottom, printer sits on top of leveling feet on the top felt insert. One picture is of prototype so printed fast without regard for finish - i can do better lol. Second is of current version - easier grip - printed without supports. I like the Sorbothane idea very much, just sharing my current tinkering.
Cheers
Digbat
Ce message a été modifié il y a 5 years par digbat
TANSTAAFL
Publié : 23/04/2020 6:45 am
TOOCH
(@tooch)
@alan
Too small for the MK2S.... It's the exact width but too short to fit the length of the feet.
Publié : 23/04/2020 9:06 pm
TOOCH
(@tooch)
Posted by: @sebastian-w5
you just need:
happy printing
Sebastian and Georg
Where can I find your STL? The one @alan gave didn't work, it's mounts are too short for my MK2S feet.
Publié : 23/04/2020 9:07 pm
