Where to buy d-Limonene in Germany ?
Shree Kumar
(@shree-kumar)
Hi Folks,
Any recommendations on where I can buy d-Limonene in Germany ? This is for replacing the PEI sheet.
Also, does anyone know if this is safe to carry in the check in baggage of an international flight ?
Background : This is very hard to source in India. I am on a short visit to Germany (Frankfurt/Nuremburg) for a week, and am looking to see if I can buy it there & get it back with me
Thanks in advance!
-- Shree
Respondido : 11/03/2017 6:53 am
devilhunter
(@devilhunter)
Re: Where to buy d-Limonene in Germany ?
In kleineren 3D Shops:
https://www.3dmensionals.de/kuehling-kuehling-d-limonen-auswaschloesung-u.a.-fuer-hips-1kg
https://www.eins3d.de/zubehor/101-d-limonene-1l-hips-loeser.html
Vorher kucken obs von auswaerts kommt, dann geht's ueber den Zoll und da bekommt man kraeftig was draufgeschlagen.
Von den Comments auf Youtube gehts aber auch ohne D-Limonene, mit etwas kraft und geschick gets auch bei 60 Grad abzuziehen.
edit: ah i see, no German
translation:
smaller shops, see links.
PEI can be pulled off at 60 degrees with some force as the youtube comments say
Respondido : 11/03/2017 11:59 am
gabriele.s2
(@gabriele-s2)
People have suggested Turpentine as a replacement for D Limonene, in case that's easier to find for you.
- Gab
Respondido : 11/03/2017 12:14 pm
StephanK
(@stephank)
If you order 2 rolls of HIPS at Trijexx Germany ( https://www.3d-druck-material.de/trijexx-d-limonen.html ) you get 1 bottle of D-Limonene for free.
1 roll of HIPS - half price for the D-Limonene.
Respondido : 11/03/2017 3:24 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Shree
I don't think it would be safe to carry on a plane; I believe it is labelled as "Hazardous" and would have to be declared and possibly confiscated.
You can buy it here: https://apcpure.com/ they ship worldwide and also sell other chemicals (eg Acetone).
Peter
Respondido : 11/03/2017 10:09 pm
jangrewe
(@jangrewe)
Just get plain isopropyl alcohol! It's dirt cheap, i bought a 10 liter can for ~10€ on ebay. You should be able to get that pretty much anywhere in the world.
PJR
 PJR
(@pjr)
IPA will not dissolve the glue under the PEI...
Peter
Respondido : 11/03/2017 10:10 pm
Shree Kumar
(@shree-kumar)
@PJR : Oh! If I can't carry it on a plane then I have to can this idea.
@gabriele.s2 : Thanks for the tip. I haven't been active on the forums for quite some time. I see there is some thread mentioning this, also reports of various sites about this!
I can get loads of turpentine here at paint shop at a low cost. Will experiment with turpentine after I come back from Germany, then!
Respondido : 12/03/2017 3:22 pm
JeffJordan
(@jeffjordan)
Miembro Moderator
😈 :mrgreen: 😈
i'm pretty sure that you'll get all the attention that you (don't) want, if you'll try to take a bottle of chemicals in your cabin baggage aboard a plane here in germany.
Respondido : 12/03/2017 6:36 pm
