Variable Fill Density
AJS
 AJS
(@ajs)
Are there any slicers that allow you to do a variable fill density in different parts of the model?
I have a nearly hollow object I want to print, but want to base to be more solid to move the center of mass down so it will stand correctly. Variable by Z is fine for this application.
I currently use Slic3r and was wondering if this is a feature in other slicers, or if anyone knows of other ways to move the center of mass of a model without placing ball bearings in pockets during the print. I would prefer not to do a huge number of full layers (shells) at the bottom, but I guess that would work.
Thanks in advance,
--ajs
Respondido : 26/06/2017 2:47 am
GertL
(@gertl)
Re: Variable Fill Density
Hi Aaron
It is possible in S3D.
Have a look at Makers Muse video on the topic.
Gert
Respondido : 26/06/2017 9:13 am
you can use a modifier mesh in Slic3r
Respondido : 26/06/2017 11:44 am
david.b14
(@david-b14)
Cura also supports this
Nice write up for Slic3r:
http://www.gyrobot.co.uk/blog/my-adventures-with-3d-printed-insoles-part-3-4
Respondido : 26/06/2017 6:17 pm
AJS
 AJS
(@ajs)
Thanks all!
Respondido : 27/06/2017 2:40 am
AJS
 AJS
(@ajs)
Thanks Joan!
Slic3r's modifier meshes are amazing, and really give me total control of the slicing process. I wish I had found out about them sooner.
http://slic3r.org/blog/modifier-meshes
Very good stuff. Adding to this thread in case someone else is looking for this.
Respondido : 03/07/2017 5:35 pm
tobias.k3
(@tobias-k3)
Thanks. I didn't know this feature but this is amazing!
PRUSA MK2
- Noctua fan 40mm
- MK2/MK3 hybrid extruder
Respondido : 06/07/2017 10:44 am
tobias.k3
(@tobias-k3)
Different aspect: Does somebody know if Slic3r allows automatically adapting the infill density within the model ?? In Cura this feature ist called: Cubic subdivision infill.
See: at 3:15
Cura Github issue: https://github.com/Ultimaker/CuraEngine/issues/381
This seems to be the optimal tradeoff between stability, printing time and used material
PRUSA MK2
- Noctua fan 40mm
Respondido : 06/07/2017 10:48 am
