Slightly bent lead screw
kniski
(@kniski)
One of the Z lead screws in my printer came slightly bent, and rubs on the top mounting bracket when it turns.
The rubbing doesn't bother me too much, but i was curious if that's going to impact the print quality much. It's not a huge bend, it deflects maybe 2 millimeters at the top as it rotates.
At the same time though the rods are straight i think, so they should stabilize the Z-movement, right?
Opublikowany : 07/03/2017 6:14 am
gabriele.s2
(@gabriele-s2)
Re: Slightly bent lead screw
In theory as long as the rods are straight you should be fine, however this will add some sideways force on the bearings - perhaps try to align them accordingly? (Ie like the manual says to align the Y bearings because they have to support the weight of the bed and the object being printed.)
- Gab
Opublikowany : 07/03/2017 7:36 am
kniski
(@kniski)
Not sure I can do much to align the lead screw. I think the rods are aligned ok though.
Opublikowany : 07/03/2017 2:34 pm
gabriele.s2
(@gabriele-s2)
I meant align the bearings. Similarly to how it's done for the Y axis: http://manual.prusa3d.com/Guide/2.+Y-axis+assembly/104#s3459
- Gab
Opublikowany : 07/03/2017 11:39 pm
