[Chiuso] Slicer problems
Vladdabad
(@vladdabad)
Slicer problems
I designed a phone case on inventor for my phone and it is drawn properly and to scale but every time i put it in any slicer it is very small a few mm long when it is supposed to be more like six inches. I have tried Slicer3d Prusa edition, Cura and they both have the same problem. Can anyone help me out?
Postato : 28/01/2018 4:54 pm
MechLink
(@mechlink)
Re: Slicer problems
what software are you using to draw it?
Are you drawing the case in Inch or mm?
Most slicer import metric so for an example if you draw it in say 6 inch long it will convert to 6mm long.
most software can convert inch to mm or vise versa.
See my stuff at
https://www.printables.com/@MechLink
https://www.myminifactory.com/users/MechLink
Postato : 28/01/2018 5:09 pm
Vladdabad
(@vladdabad)
Re: Slicer problems
I am using Auto desk inventor and its in inches, I will try converting it it.
Postato : 28/01/2018 5:52 pm
Vladdabad
(@vladdabad)
Re: Slicer problems
I tried converting the drawing from inches to metric but it did not work.
Postato : 28/01/2018 5:59 pm
kevin.r5
(@kevin-r5)
Re: Slicer problems
If you've modeled in inches and need to scale to mm, you could scale your model in slic3r to 2540 %.
-Kevin
Postato : 28/01/2018 8:16 pm
Jeff Cron
(@jeff-cron)
Re: Slicer problems
Inventor exports in mm by default.
Click on File->export to CAD format->select .STL as file type then select Options->Units->Inches
Postato : 27/03/2018 10:21 pm
Jeff Cron
(@jeff-cron)
Re: Slicer problems
Click on File->export to CAD format->select .STL as file type the select Options->Units->Inches
cogof40852
(@cogof40852)
RE: Slicer problems
If you put it in on any slicer it is very small a few mm long. So, check its mm length when it is supposed to be more like six inches is correct or not.
Postato : 15/01/2020 6:20 am
