Replacement e3d V6 hotend
mads.e
(@mads-e)
Hi all
i had a accident with my printer, were a failed print covered the bottom extruder body, while trying to get it of i damaged the e3d hotend.
so my question is which of the following kits its the correct one to purchase for the i3 mk2s
Direct: http://e3d-online.com/E3D-v6/Full-Kit/v6-175-24v
or
Bowden addon: http://e3d-online.com/E3D-v6/Full-Kit/175-universal-bowden-full-kit
Thanks in advanced
Mads
Opublikowany : 04/04/2017 10:22 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Replacement e3d V6 hotend
Neither. You need the 12V direct: http://e3d-online.com/E3D-v6/Full-Kit/v6-1.75mm-Universal
Or you could purchase only the damages parts.
Peter
Opublikowany : 04/04/2017 11:46 am
mads.e
(@mads-e)
Ok thanks alot.
its weird i asked the support chat and he said it was 24v
Opublikowany : 04/04/2017 12:34 pm
dimitristhass
(@dimitristhass)
Sometimes i get the impression that they don't know what they sell
Opublikowany : 04/04/2017 12:53 pm
PJR
 PJR
(@pjr)
The other thought here - I believe PR are shipping with a 40W heater cartridge at present and I don't know how long they have been doing this.
The standard cartridge which comes with the extruder kit is 30W I believe. You may need to ask them to ship the 40W, on the assumption that you are happy with that.
Peter
P.S. My Mk2 uses a 30W heater without any issues, although the reason PR changed to 40W was to avoid the over-cooling issues. Personally, I am not OK with a 40W heater, for various reasons.
Opublikowany : 04/04/2017 5:15 pm
JeffJordan
(@jeffjordan)
Member Moderator
@Peter: just to let you know: my kit already came (end of last november) with the 40W heater (red cable and below 4 Ohm resistance, including wiring).
worked flawless ever since...
Opublikowany : 04/04/2017 10:38 pm
PJR
 PJR
(@pjr)
If you don't mind ignoring the E3D warnings and pushing the fuse to it's limits, that's fine.
Dan at E3D:
both the 25w and 30w heater cartridges that we supply have no problems in maintaining any temperature you want to throw at it. The 40w heater cartridge will mean that the HotEnd will get to temperature much quicker but it will not effect the way that the cartridge maintains the temperature. 40w heater cartridges' also need a lot more supervision compared to 25w or 30w cartridges.
Peter
Opublikowany : 05/04/2017 2:19 pm
JeffJordan
(@jeffjordan)
Member Moderator
If you don't mind ignoring the E3D warnings and pushing the fuse to it's limits, that's fine...
Peter
😈 about 1 amp more or less.... i don't care.
➡ at the rambo, with it's "car-fuses" it shouldn't be any problem. it would be more severe if we would use a ramps with its boiling ptc polyfuses.
i'm more concerned about the current the heated bed requires, which really needs supervision.
at my "spareparts to 2nd printer project", i use a genuine MK42 heatbed and a ramps 1.4.... and already managed to melt down the power supply connector :mrgreen: because it's only approved up to 12 amp and the heatbed requires 15 (so i had to replace it with terminals that use screws).
Opublikowany : 05/04/2017 4:29 pm
