Paper catching on xyz calibration
ryan.f15
(@ryan-f15)
I got the "bed leveling failed sensor triggered to high" error today so i went to recalibrate. When I did, the paper caught and was dragged a little on calibration point two. I followed the directions and turned the printer off. I tried it again with the same effect. What should I do here? It didn't do this before.
Opublikowany : 04/11/2017 2:52 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Paper catching on xyz calibration
Lower the probe - just a little bit.
Peter
Opublikowany : 04/11/2017 10:20 am
ryan.f15
(@ryan-f15)
I'll give it a shot. I'm having issues with the pla not sticking and I've got a raft just for that.
Opublikowany : 04/11/2017 8:49 pm
AJS
 AJS
(@ajs)
These steps will help with adhesion:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Opublikowany : 04/11/2017 9:25 pm
