Mk2s + multi-material upgrade, which first?
prusayo
(@prusayo)
My mk2s and multi-material upgrade has shipped. Which one do I do first? Are there any gotchas I should be aware of before starting?
Opublikowany : 19/05/2017 9:27 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Mk2s + multi-material upgrade, which first?
Mk2S upgrade first. Be patient; print for a couple of days and then add the MM upgrade.
Peter
Opublikowany : 19/05/2017 10:40 pm
prusayo
(@prusayo)
Good idea thanks! I always rush things...
Opublikowany : 20/05/2017 12:25 am
PJR
 PJR
(@pjr)
FWIW, the only thing I changed on my Mk2 was the cable management at the back of the extruder and while it was in bits, I changed the X bearings.
Peter
Opublikowany : 20/05/2017 8:49 am
