First things to print for MK2?!
Wirlybird
(@wirlybird)
Hi all, please don't jump on me for this and I am looking through the forum! I was hoping for your thoughts on the first items I should print for the new MK2? Add-on's, upgrades etc. I wanted to put one of my printers to use while I wait for the MK2 to arrive by making some things for it that would be good to do.
Are there other upgrades you guys would recommend right off such as fans, bearings etc?
I still have so much to read on the forums here so thank you for indulging me!!
W
Opublikowany : 12/10/2016 2:18 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: First things to print for MK2?!
Hi
Personally, I have quite a few spares on my shelves:
  • Extruder fans
    Part Fans
    Nozzles
    PTFE tube
    Complete extruder kit
    Extruder socks
    Linear Bearings
  • If you don't have it, you will need it; if you do, you won't (very often).
    As for printed parts, that is something I have never needed, except for when I mod one of them.
    Peter
    Opublikowany : 12/10/2016 3:37 pm
    Wirlybird
    (@wirlybird)
    Sounds about right for my other printers! Always have a complete extruder setup with steppers ready to go! Plus all the other goodies!
    I skimmed a few posts and noticed talk about bearings. Are there upgrade bearings that are worth looking at or are the supplied ones just fine? I figure if there are some parts like that, that would benefit from an upgrade then best to do it during initial assembly.
    Opublikowany : 12/10/2016 4:01 pm
    JohnOCFII
    (@johnocfii)
    Buy a set of the E3D socks. Cheap, and will help you if you need to print above 220C with the run operating at high speed. http://www.filastruder.com/products/silicone-socks-3-pack
    A number of people have had problems with wide prints causing the spool feed to go over the side of the spool, and causing a mess. This can be solved by a filament guide. There are many out there to print. I printed this one: http://www.thingiverse.com/thing:1688923 created by one of the forum participants.
    I also printed the Prusa Research Anti-vibration feet. http://www.prusa3d.com/prusa-i3-printable-parts/#_ga=1.77512149.1794524405.1468079777
    The image is misleading, as it should be printed as just the perimeters - no infill.
    The bearings for some people are fine. For others, they are loose, and/or cause a great deal of noise. I'm not sure of the best solution here, but two options seem to be: a) just try more/different LM8UU bearings, or b) try the IGUS Drylin bearings: https://folgertech.com/products/igus-rj4jp-01-08-8mm-linear-bearing-to-replace-lm8uu
    John
    Opublikowany : 13/10/2016 12:47 am
    ayourk
    (@ayourk)
    John
    For me, I changed out my LM8UU bearings on my Y-axis for some SKF LBBR 8-2LS bearings. They are slightly stiffer and cover more surface area on the linear rods. The old ones gained too much slop from multiple misalignment issues.
    There are all sorts of modifications and improvements that can be done to the MK2. Here are some of my highlights:
  • MK2 Alignment sticks or a good pair of digital calipers that can go up to at least 180mm. You want the linear rods to be spaced 170mm on center apart as measured from both the front and rear of the machine and you want the Z-frame to be spaced 100mm from the rear of the machine to the Z-Frame. I have my Calibrate XYZ always saying that "all axis are perpendicular" because of this.
  • Replacement Y-axis motor mount This one allows you to use NEMA dampers to make the printer quieter. There are multiple posts in the Improvements about making the MK2 quiet.
  • Y-Motor Brace If you got the kit and not the prebuilt, chances are, it doesn't come with this piece.
  • MK2 Cable Chains This is a preferences thing, so if you don't want chains, then skip this. I personally love my cable chains and it makes it so easy to add and remove wires with each chain link having snap clips on them. You only really need 1 full range chain link. I've been modifying the X-Carriage EL link quite a bit because I had difficulty getting a stable print. I finally have it working, but I've had to include built-in supports that can be cut away with a razor blade.
  • Noctura 40mm Fan adapter There are multiple posts in here about moving to a Noctura, this thread is closest to having some sort of model. I've made my own design based on Patrik's work. It can print in this orientation without supports. You will need to use M3x14 screws vs the M3x18 screws that mount the 30mm fan into the hotend body. This is a press fit design, but it is there so if you want to modify it so that it uses screws onto the hotend body, you can do that too. The pegs are spaced 24mm on center. I'm going through testing and still modifying the model. Follow the above thread for my progress.
  • MK2 X-Carriage for Cartridge Thermisistors I recently upgraded my hotend with the Block and Sock upgrade from E3D and found the connection on the back of the thermisistor clunky. So I redesigned it so that it fits nicely tucked away inside the X-Carriage and included a clip vs using a zip-tie.
  • You probably want to consider some sort of wall mounted spool holder or some other spool holder solution above the MK2 vs having your spools mounted on your Z-Frame. I've encountered a few spools that won't fit above on the provided spool holders, namely ColorFabb 2.2kg spools. I took an approach similar to Thomas Sanladerer's approach.
  • Check out my other posts. I have similar info organized like above.
  • Dimensions PNG
    and an 8 inch (200mm) or greater caliper is recommended.
    Opublikowany : 13/10/2016 2:07 am
    christophe.p
    (@christophe-p)
    Member Moderator
    Yeah, shameless advertisment: Print my Spool holder !
    (And very nice list from ayourk)
    I'm like Jon Snow, I know nothing.
    Opublikowany : 13/10/2016 10:24 am
    Wirlybird
    (@wirlybird)
    Awesome info everyone! Thank you very much!! I am curious to see if I can adapt my dry box set up to work with this printer. It will be perfect for the 4 color option since it holds 5 spools. I can put up a pic later when I get home.
    Opublikowany : 13/10/2016 1:28 pm
    Wirlybird
    (@wirlybird)
    John
  • Thanks for all of the info. I looked at the bearings, $30 each!! WOW.
    Opublikowany : 14/10/2016 4:32 am
    Wirlybird
    (@wirlybird)
    John
  • Is there a file for the alignment sticks where the items are separate? It is to big dimensionally as one file to print on my other printer.
    Opublikowany : 16/10/2016 12:50 am
    ayourk
    (@ayourk)
    If you are using TinkerCAD, you can copy my project, open up the project, select each model individually then select Download for 3D printing and put a check mark in the check box of selected model only.
    If you use Simplify3D, you can use Mesh --> Separate Connected Surfaces.
    Dimensions PNG
    Opublikowany : 16/10/2016 1:15 am
    Wirlybird
    (@wirlybird)
    Cool, thanks for the info.
    Also I was trying to figure this out in S3D. I knew I had read about it somewhere. Thanks.
    Opublikowany : 16/10/2016 4:45 am
    Hughe
    (@hughe)
    The nuts will get loose. Once the printer delivers consistent quality, apply glue or locktight to all the nuts.
    For stepper motor pulleys, I apply locktight on set screw and front of pulley and the motor shaft.
    This is the anti-vibration foot.
    Opublikowany : 17/10/2016 11:55 am
    JohnOCFII
    (@johnocfii)
    Do you loosen the nuts to get Loctite under them, or just on the outside, and hope it holds, or drips into the threads under the nuts?
    Opublikowany : 19/10/2016 4:40 am
    Marc
     Marc
    (@marc-9)
    Loctite only hardens when there is no more air around. So you should loosen them, apply it and tighten it.
    You could try otherwise but I would not expect it to be working as it is supposed to be.
    Opublikowany : 19/10/2016 11:52 am
    Omikron
    (@omikron)
    Correct. Loctite is an anaerobic adhesive and does not need air to set.
    That said, there are wicking grades of loctite such as Loctite Green that can be applied to the edge of the nut after its tight.
    Opublikowany : 19/10/2016 2:40 pm
