dimensions mk2s for enclosure
Ido
 Ido
(@ido)
I wont be getting my mk2s for a few week, so that should give me plenty of time to build an enclosure. But not having the printer right in front of me its pretty hard to guess its size. I searched the forum and the website but couldn't find an answer.
Could someone tell me the sizes of the X, Y en Z axes, in other words, what dimensions should my enclosure be. I am planning to place the LCD screen outside the enclosure.
Publié : 15/05/2017 7:30 pm
murloc992
(@murloc992)
Re: dimensions mk2s for enclosure
If you have IKEA where you live, IKEA Skarsta tables get stacked with acrylic sheets on sides and some "fancy" IKEA doors and hinges to make the state-of-the-art enclosures.
Publié : 15/05/2017 9:26 pm
Ido
 Ido
(@ido)
you mean an ikea lack table? already got 2 of those 🙂
Just wanted to know the dimensions of the mk2s
Publié : 15/05/2017 9:31 pm
kevin.t8
(@kevin-t8)
X = 43 cm
Y=35cm.
z=37.5cm
This is without the screen attached. The screen would add 7.5cm .
I will be using two Lack tables so I will have to put the spool of filament on the top of the table.
Hope this is the info you were looking for.
Publié : 16/05/2017 4:03 pm
Ido
 Ido
(@ido)
thanks kevin, good info. So it seems it will fit perfectly.
btw, perhaps for inspiration, I am going for this design http://www.thingiverse.com/thing:2212749
Publié : 16/05/2017 7:53 pm
kevin.t8
(@kevin-t8)
ido.d
Yes, that looks like a good setup and I like the idea of making it a little taller. I did add some LED lights and a Raspberry Pi with Octoprint which so far has worked well for me. Overall this seems to be a low cost way to enclose the printer.
Publié : 17/05/2017 12:58 am
Ross
 Ross
(@ross)
I am making an enclosure based on the 'HotBox' design.
That design was really for the Taz 3D printers and includes a vent for the 'eBox' on the TAZ.
Does anyone know if the power supply on the Mk2S needs venting or if it needs a fan for cooling when it is in an enclosure.
I am installing two 140mm variable speed Noctua fans (one feeding in cool air and the other extracting hot air) for general ventilation but not sure if I need something specifically for cooling the Mk2S power supply box.
Publié : 29/05/2017 7:05 am
Rob Nance
(@rob-nance)
I mean, I think you answered your own question. With your fan setup you proposed, that is going to move WAY more air than would ever move through a normal room inside there.
Publié : 30/05/2017 1:47 am
nathanael.b
(@nathanael-b)
Kevin failed to consider the print bed movement. I‘d add another 10cm or even a bit more to allow the print bed to fully move fore and aft.
Hope this helps someone in the future. 🙂
Best regards!
Publié : 28/09/2018 8:08 pm
BillC
(@billc)
Standard Lack table is 550mm x 550mm outside edges, this allows MK2S to fit inside and lets bed move fully forward and bed cables move fully backward without restriction - IF - the LCD is mounted outside the enclosure. There are many mounts for external LCD and there are also a couple of options for LCD mounts to fit the side rods so you can install the printer across the enclosure.
You also need to give thought to how and where you will mount your spool holder(s) and add enough height for that. My enclosures are 600mm high.
Bill
Tagaytay City, Philippines
Publié : 29/09/2018 3:34 pm
