Calibration help please!
unknwnrider
(@unknwnrider)
Recently upgraded to the MK2 and the calibration is killing me.
I've worked through several issues but I'm totally stuck at this point.
I'm running the Beta 3.0.5 firmware. I can print the below JEEP logo without issue when it is printed side to side, however when I try to print it front to back I'm having major issues with material adhering to the nozzle and causing the first layer to become nothing but a bumpy, scarred mess.
My print bed is perfectly level. My X-axis is level and perpindicular to my y-axis. The Z rods are straight.
I've been running a live adjust value of -0.550mm which works great for the side to side prints but will not adhere when running front to back. To compensate, I've tried a -0.600mm value for the front to back but it just cloggs up the nozzle and will not produce a decent print.
I've tried ABS, PLA, PETG but I get the same result regardless of material.
I'm thinking about downgrading to 3.0.3 firmware but I feel like this is a hardware issue.
Any help anyone may have would be greatly appreciated. I'm going nuts here trying to trace this down.
Respondido : 17/07/2016 4:48 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Calibration help please!
That is well over-extruded on the first layer.
Your nozzle is too close to the bed on the first layer, looking at the print, I would think you need to raise by about 0.1mm.
Looks as though your bed could do with a good clear with IPA as well.
Peter
Respondido : 17/07/2016 12:02 pm
Shree Kumar
(@shree-kumar)
In the second image you have posted (Jeep logo front to back), the infill lines are outside the skirt for the second "e". I face similar problems when my X axis pulley is loose. To be sure, ensure that both X & Y axis belts are tight & the pulleys screws are tight.
Respondido : 17/07/2016 12:07 pm
unknwnrider
(@unknwnrider)
I've tracked my issue down to the frame sitting square with the y-axis. For the life of me I cannot get it to sit square. If I make the frame square, the y-axis is tilted. If I level up and untwist the y-axis, the z frame is not level or square. I think it has to do with the PSU holder not fitting the way it should as I purchased the upgrade.
Not exactly sure how to correct this issue outside of taking the PSU off and trying to remount it somewhere else...
Respondido : 17/07/2016 6:08 pm
unknwnrider
(@unknwnrider)
Yeah, my PEI sheet is pretty much destroyed as well as I've been trying to sort this out. I was so happy with my i3 and I'm to the point where I might just downgrade back to the i3.
Respondido : 17/07/2016 6:15 pm
PJR
 PJR
(@pjr)
OK, so disconnect the PSU from the Y frame; you can always print a part to connect it up later.
Peter
Respondido : 17/07/2016 6:54 pm
unknwnrider
(@unknwnrider)
So I've realigned EVERYTHING and things seem better.
I've done a perimeter test where I've placed a jeep logo on all 4 sides of the bed. The two placed on the outer side of the bed (facing north-south) seem to not as decent as the two on the top and bottom (facing east-west).
What I have noticed is the outer perimeter line that is run first tends not to ahdere as well as the shape perimeter and I'm not quite sure why. If I decrease the live adjust I get a slight over extrusion when the jeep logo begins the infill....still not sure why that is
Respondido : 17/07/2016 10:57 pm
