X endstop not hitting (Solved)
prusayo
(@prusayo)
After adding MM I ran self test and x endstop fails to hit button. I can see that cable with wrap is physically hitting Rambo case a couple of mm before endstop is hit. Should I just add a piece of plastic so it triggers endstop?
Opublikowany : 16/07/2017 4:13 am
prusayo
(@prusayo)
Re: X endstop not hitting
Orientation of zip ties and cable wrap technique was the problem. Now it works.
Opublikowany : 16/07/2017 5:36 am
