stringing after MM upgrade
Hi all,
I got my MK2S kit early this week and enjoyed building it. The print quality is as good as the Ultimaker 2 that I have at work (I'm a Mech Eng) and I was really impressed with the dragon off the SD card.
I was going to wait a month or so, but I decided to fit the Multi Material Upgrade the next day. 🙂 Now, running the same filament, with the same temperatures and the same file off the SD card, the dragon looks all stringy...
* I don't think its the Bowden tubes since the UM2 has them a doesn't have this problem
* It is a different hot end, so it could be linked to that. Temperature reading different?
* I am using the same file off the SD card. Are there settings in the gcode that are adjusted depending on printer, e.g., retraction distance?
Any suggestions would be much appreciated.
Thanks
Carl
Napsal : 23/06/2017 8:49 am
