Slic3r PE wants to fill something I don't want filled
Welchomatic
(@welchomatic)
If any Slic3r experts are around I could use your help. I've spent the day modelling something to hold oily cotton balls on a bathroom counter. The cylinder cutout is for the oil, the half sphere is for a cotton ball. Slic3r PE Preview is showing me that it intends to fill the hemisphere. Can anyone tell me what I've done wrong?
https://www.thingiverse.com/thing:3319288
Appreciate the help. Oh, and this will be single color, but my printer is an MK3 MMU 2.0, so I asked for help on this forum.
Postato : 28/12/2018 9:11 pm
Re: Slic3r PE wants to fill something I don't want filled
shouldn't be a problem
downloaded the cup,
loaded in Slic3r, found it standing on the rim of the cup,
sliced, and cup wasn't filled,
so rotated -90 degrees on X axis, and sliced with cup down
and again, it seemed to slice ok.
what filament are you using?
Postato : 28/12/2018 9:27 pm
try this
Joan
Postato : 28/12/2018 9:30 pm
Welchomatic
(@welchomatic)
Hi joan.
I see so many posts from you, and am honored that you are helping me. But I think there's a bit of confusion here. It's not that the STL file is 90 degrees rotated. It's that the base wants to fill. Let's see if I can post 2000 words worth of pictures to show the problem.
Here you can see that I have a watertight object (rotated in a position easily printed)
And here you can see that it's infilled. If I go up a few layers, the hollow hemisphere winds up with a solid top.
I'm confused. I really can't see any reason for this fill.
Postato : 28/12/2018 10:07 pm
Welchomatic
(@welchomatic)
DERP!! I figured it out.
When I made the two items I had a hollow ball with a thick skin, thinking I needed the cap. I sliced it in half and used that for the base, but never got rid of the outside layer of the hemisphere. So I had a fake inside image which was covered up by the outside walls. Usually I do a great job of making things manifold, but I never carry one object into another one like I did here.
Postato : 28/12/2018 10:13 pm
