Printing 205mm tall model
oakl
 oakl
(@oakl)
Hi.
I know the spec for the pruza Z axis is 200mm. However when moving axis manually in the menu I can move the Z axis to 205mm and still there are slightly less than 1mm left of clearance before running out of mechanical travel.
Question is: Will it be possible to print a 204mm tall object?
Opublikowany : 01/04/2018 9:06 pm
Mabau
(@mabau)
Re: Printing 205mm tall model
Wiith a little bit of modding, you can print up to the upper end of the frame (26 cm possible https://shop.prusa3d.com/forum/improvements-f14/30-more-build-volume-26-cm-build-height-working-t6088.html#p42902 )
Just looked in the firmware:
You should be able to print you model without changing anything.
Opublikowany : 01/04/2018 9:20 pm
oakl
 oakl
(@oakl)
Thank you for your input.
Should be possible is great, but if someone had actually tried or know for sure it would be even greater 😉
I am about to start a 50 hour print, would be a shame if it stops 4mm before it is finished.
Maybe I will make a small and tall fast-printing part just to check first.
Opublikowany : 02/04/2018 6:08 pm
