Which part should I print?
krevety
(@krevety)
Hello, our PINDA sensor holder has broken and I would like to reprint the broken part on another printer.
I was searching the printable parts here but none looks similar to the current broken one. Actually I do not know what printer do we have, all it says is MK2 so I have searched over MK2s/2.5/s parts etc. but with no success. Thanks for any help.
Best Answer by JoanTabb:
I believe this is the part you are looking for!
which is available at this link,,,
https://www.prusaprinters.org/prints/88236-i3-mk2-printable-parts/files
Settings
If you decide to generate your G-codes, it is recommended to use:
Material: PETG0.2 mm layer height QUALITY presetInfill: 20% GRID
The 'Fan-shroud'- part, which directs air from the print-fan to the part, should be printed in ASA or ABS, but otherwise with the same settings.
If you have printed your own plastic parts, check this article for guidance on post-processing.
https://blog.prusaprinters.org/postprocessing-of-3d-prints-step-by-step_29270/
Veröffentlicht : 23/02/2022 8:11 am
RE: Which part should I print?
Settings
Veröffentlicht : 23/02/2022 9:49 am
krevety
(@krevety)
Hello Joan,
thanks for you prompt response. I have looked at the link and 3D model and I sincerely do not think this is it. What I need is the part which also serve as PINDA holder. Original pictures were kinda cropped so I added a detailed one with the broken part. Cheers!
Veröffentlicht : 23/02/2022 10:47 am
like this?
this is the link I Identified!
Veröffentlicht : 23/02/2022 11:03 am
krevety
(@krevety)
Yes thats it, thanks a lot!
And I can see it now in the former post. Originally it was showing me the fan nozzle part, do not know why. But it is solved now 🙂
Veröffentlicht : 23/02/2022 1:29 pm
