Power Cord replacement
donna.p
(@donna-p)
We have the Prusa i3 MK2s here at our community center. Our first one. I have learned a lot his year about 3d printing but still need some advice. Someone took the power cable and I am in need of a replacement. I have been researching how to choose a power cord for a power supply but not sure I understand it yet. The cable should = the voltage of the power supply?
I did find one cable lying about it is labeled 15A 125v....could this be it?
Any assistance would be greatly appreciated...
Best Answer by vintagepc:
It's a standard IEC connector. Any computer cable should be more than adequate.
The cable should be marked with a voltage greater than or equal to the wall voltage where you live, and a current rating greater than the current draw of the device.
Napsal : 29/05/2019 10:32 pm
vintagepc
(@vintagepc)
RE: Power Cord replacement
Napsal : 29/05/2019 11:24 pm
donna.p se líbí
donna.p
(@donna-p)
Thank you so much!!!
Napsal : 30/05/2019 4:01 pm
gminnick
(@gminnick)
What is the draw of the device?  I have built an enclosure and want to replace the cable with a left angle connector.  The one I have found is an 18AWG rated at 10A.  However the original cable is 16AWG (unsure of amp rating as not printed on cord).  Thanks!!
Napsal : 31/08/2019 2:58 pm
Dave Avery
(@dave-avery)
less than 300 w , so 2.5A @ 120v or 1.25A @ 240V
Napsal : 31/08/2019 3:18 pm
gminnick se líbí
