Heatbed doesn't heat over 98C
Noogie
(@noogie)
Hello,
I recently bought a used mk2s (kit) and it prints PLA beautifully.
Only 2 things wrong with it:
1. There is small damage to the heatbed itself, a hole in the PEI with some fibers sticking from it - So I just print off-center.
2. I can't print PETG properly, I did the "Live Z" and the filament adheres to the bed at 83C, but when I print I get almost no adherence and very low quality print which detaches quickly.
Over the last few days I received multiple different errors such as "Thermal Runaway" and "Heatbed Error", and when I did the bed temp test, it never got past 98C - in a closed room, with no fan or AC, it got so hot the hotend fan started working(!).
I have the upgrade kit for the mk2.5 and all the extruder parts printed, but without the rambo enclosure and heatbed connector cover.
As far as troubleshooting goes, I checked the thermistor is attached in place, the heatbed leads are soldered in place, all connectors on the rambo are secured in place, I blew a hairdyrer on the heat and saw the temperature rise and I raised the power supply voltage to 12.48V.
What to do?
Can I install the mk52 heatbed without doing the whole mk2.5 upgrade? and without flashing new firmware?
Respondido : 24/10/2018 8:24 pm
Noogie
(@noogie)
Re: Heatbed doesn't heat over 98C
anyone?
Respondido : 01/11/2018 1:09 pm
Noogie
(@noogie)
Anyone???
Respondido : 06/11/2018 10:12 pm
Noogie
(@noogie)
Seriously????
Respondido : 09/11/2018 6:29 pm
alexander.s27
(@alexander-s27)
How hot do you want your heatbed to get?
98° is seriously high.
The slightest whiff of air, not to mention a running fan will cause a temperature error.
Respondido : 09/11/2018 11:51 pm
Some folk insulate below the Heat bed.
Cork has been used.
Some folk have raised the power supply voltage a little
Others have used an enclosure. To reduce environmental effects
Mine runs about 12.7 volts. Haven't checked since I fitted New heated think I raised it when it was a mk1. With glass print surface.
Regards joañ
Respondido : 10/11/2018 1:12 am
danielkrah
(@danielkrah)
When the power supply delivers 12v spot on it is to low for the mk42
12.5V worked fine for me on my orballo mk42 and the prusa mk42.
Respondido : 15/11/2018 11:15 am
Knickohr
(@knickohr)
Miembro Moderator
You can go up to 13.5 Volts by trimming your PSU, but this is not recommended !
Please do an PID-tuning on your bed and hotend too.
If you need such high printbed temperatures it is the better way to isolate your bed and printing in a housing.
Thomas
Respondido : 16/11/2018 9:13 am
Noogie
(@noogie)
Thomas
I tried doing the bed PID, it didn't go over 98 C and so it couldn't finish the PID cycle.
As I wrote, the bed is already at 12.48V.
Respondido : 18/11/2018 1:47 pm
Noogie
(@noogie)
Do you print with PETG?
Respondido : 18/11/2018 1:48 pm
alexander.s27
(@alexander-s27)
Yes sure. Mostly PETG. PLA only for Indoor parts. 85° for the 1st layers. All the others 75°. PETG sticks like hell to the PEI sheet.
Respondido : 18/11/2018 4:41 pm
