Prints not correct
les.b4
(@les-b4)
Prints not correct
Hi Guys,
Need help in finding out why my prints are not working out as expected. Attached a pic showing a flattend edge that should have a nice curve like
other parts of the model. It just seems to take a shortcut and then starts printing correctly. I am still in my infancy with 3d printing.
Any help would be appreciated. Thanks
Kind Regards
Les
Publié : 08/07/2020 7:01 pm
newtag
(@newtag)
RE: Prints not correct
Hi Do you mean that both parts have been done with the same Gcode ?
Probably not
The clue of your problem is in the slicer for sure
Publié : 14/07/2020 5:40 pm
les.b4
(@les-b4)
@tagada-b
Thanks for replying. Yes both parts done with same gcode. However i found if i placed the model with the side containing the two holes against the table it printed fine. Also had someone print the model as i did and got similar results. So i have just assumed it was a problem with how 3d printers print or the model was drawn. If i [placed the model with either  side(not hole sides) against the table it was always the side closest to the table that was deformed.
Les
Publié : 14/07/2020 7:06 pm
@les-b4
Hi Les,
as the curved surface builds away from the build plate it is initially almost horizontal, so the filament  at the beginning of the curve sags due to gravity,
this continues to happen until the curve gets to about 40 degrees to the build plate, at which point the next layer gets sufficient support from the previous layer, that it doesn't sag.
some designers purposefully make the lower edge of a surface like that into a chanfer so that the part leaving the  build plate, is at 45degrees and is able to self support...
Others use supports, but that can get messy...
Publié : 14/07/2020 7:38 pm
les.b4
(@les-b4)
Hi Joan,
Thanks for the reply. I did try supports but still the same.
Regards
Les
Publié : 14/07/2020 11:20 pm
richardgondeck@gmail.com
(@richardgondeckgmail-com)
I'm having dimensional accuracy problems. I created a 24.5mm cube and it printed with different dimensions on each axis. Is there a corrective app or firmware patch available?
Publié : 10/10/2020 10:29 pm
jsw
 jsw
(@jsw)
Posted by: @rick
How far off are things?  Are the measurements within 1% or so?
Publié : 11/10/2020 1:55 am
1.3mm in 25, roughly.
Publié : 11/10/2020 11:47 am
Membre
@rick
Depending on the filament, you can get 0.8% shrinkage.  This is 5.2% so it is a tad high.  What filament?
Publié : 11/10/2020 1:07 pm
jsw
 jsw
(@jsw)
Something is definitely wrong. Which plane(s) shows/show the error, and how much in each plane?
Is this a new printer, or one that was accurate and all of a sudden became inaccurate?
Publié : 11/10/2020 2:35 pm
